It is currently Fri 22. Nov 2024 19:05:30
[ 2 posts ] |
Dudemeister
Posted: Thu 17. Nov 2022 8:31:53 |
I'm still trying to get a grip on what some of telemetry sensors actually tell me.
On a Spirit GT / Castle Edge ESC / FrSky ACCST 2 RX I get the following:
RX ?? RxBatt Receiver / BEC Voltage Fuel Vibrations ADC2 ?? RBOX V1 Main Battery Voltage RBOX A1 Main Battery Amperage?? VFR VFR RBOX C1 ?? RBOX C2 ?? TEMP 1 ESC Temperature GPS Alt Altitude (Seems t work without GeoLink. Barometer in the Spirit GT?) RPM RPM
I'm interested in getting more info on the sensors with ??. Also, The RBOX A1 is a Amp erage display. But what is it supposed to show, the total battery capacity, the rema ining capacity?
Also, what the difference between RSSI and VFR
Dudemeister
Posted: Fri 18. Nov 2022 18:42:21 |
I'm running this on a FrSky X20S with Ethos, and assuming this is similar to the OpenTX integration Telemetry, then I think some of the questions are answered
RX = ?? RxBatt = Receiver / BEC Voltage Fuel = Vibrations ADC2 = ?? RBOX V1 = Main Battery Voltage RBOX A1 = Main Battery Amperage (Is this a value that's calculated or manually entered? IS it the battery rated capacity?) VFR = VFR RBOX C1 = Battery Consumed Capacity (in mAh) RBOX C2 = BEC Voltage x10?? IS this the same as RxBatt? TEMP 1 = ESC Temperature GPS Alt = Altitude (Seems to work without GeoLink. Barometer in the Spirit GT?) RPM = RPM
[ 2 posts ] |
Users browsing this forum: No registered users and 83 guests |
