It is currently Sat 23. Nov 2024 4:13:24
 Post subject: Wobbles & Jerks
PostPosted: Sat 05. Nov 2022 2:20:57
I'm still trying to solve these issues running a uSpirit on a Blade 230S that has an extended tail and larger rotor blades (270mm)... Have searched though this forum for various settings and so far no luck... She jerks (yaw) and wobbles (roll) ... Now the battery is slightly larger than stock and is mounted lower than stock, under the ship in between the main gear making the CG lower than stock...
I want to send my settings in for analysis, how do I get the Spirit settings for emailing?
Would appreciate help finally getting rid of these issues...
 Post subject: Re: Wobbles & Jerks
PostPosted: Sat 05. Nov 2022 12:20:03
Hello Trondyne,
I can only help you how to backup your settings from Spirit Settings to your harddisk -
enter a name for your profile and save it - then simply upload the file here in the forum - that's actually it -
PostPosted: Sat 05. Nov 2022 22:42:05
Ok thanks I wasn't sure if the developer used those files to inspect settings on units with issues...
PostPosted: Sun 06. Nov 2022 14:57:02
Hello Trondyne,
the developer is here in the forum and also downloads the files from here, he will certainly be able to help you - there may also be users here who have converted the 230S to Spirit FBL -
PostPosted: Mon 14. Nov 2022 23:11:03
I had a similar issue. It was a bad servo.
Looked fine on a servo tester, but just idle on the bench I could see it moving without TX input. Changed out servo and problem solved.
Users browsing this forum: Bing [Bot] and 35 guests
