... Continued:
Here are the vibration analyzer output images
Having gone through all this, I think I may have found the problem, although I don't understand why. In general, the rescue mode works correctly on the bench, but when I get to the field it, it goes weird.
Today, when I first put the heli on the bench, rescue was working fine, then after a while (after I did all the tests and stuff), it started to act up. That's when I took the video above.. At the same time I noticed that the GeoLink was solid blue, so even though I'm indoors, it acquired enough satellites for a solid link. I looked it up on the map and it pointed to the correct location. On a hunch, I pulled the plug on the GeoLink, and Rescue started working correctly. As soon as I plugged it back in and it turned solid blue, rescue started to freak out.
So the big questions, is why is the GeoLink affecting the rescue behavior? How do I fix this? Does the Geolink require re-calibration?
