It is currently Fri 22. Nov 2024 6:50:04
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu 10. Nov 2022 20:46:00
Tested with a 2nd transmitter: Horus X10S ISRM 2.1.6 ETHOS 1.4.2.
Same problems as with the X20, in addition, it is no longer possible to scroll up in the application once you have scrolled down.
PostPosted: Thu 10. Nov 2022 21:34:54
X20S HD 1.3 Ethos. 2.2.2 spirit Gt. TDMX Receiver (2.4 & 900)..S-bus wired to rudder.. S.port wired to System, red wire removed, configured to F-Port but unable to change scripts at all. Nothing, but servo operation as normal.
Does anyone have a positive grip on wiring please?
PostPosted: Thu 10. Nov 2022 22:14:24
https://manual.spirit-system.com/index. ... rSky_FPort
You have to connect the S-port, + and - from the receiver to the RUD port of the Spirit. The S-Bus cable is no longer needed. In the transmitter you have to change from S-Port to F-Port under RF-System/RX/SET/OPTIONS.
PostPosted: Thu 10. Nov 2022 23:12:54
Hi and thanks for your reply, i have that set up on another spirit gt, running full telemetry from hobbywing 200a plat 4. same TDMX Receiver but still no set is able to be changed, all the scripts are readable but nothing can be edited.
PostPosted: Fri 11. Nov 2022 3:07:11
I'm running an X18S with an Archer RS on F.port.
Initially script only had grayed out items. Updated Ethos from 1.4.1 to 1.4.2. Everything populated and I can change them and save (I'm pretty save worked). It did seem like the Sporit GT stayed in the configuration with a slow blink. Took a power cycle to get it back. Idk if Ethos is not really exiting when you back out to the main screen or what.
PostPosted: Fri 11. Nov 2022 10:14:46
thank you for your reports!
Today we released updated scripts with improved Save Settings button - previously there was no notification so people might think nothing happened. Now you will see notification dialog.
Added button for Closing the script directly.
Link for new scripts: https://spirit-system.com/dl/ethos/spir ... .4.3r2.zip
PostPosted: Fri 11. Nov 2022 10:36:14
Ethos 1.3 hw1.4.0 fw 2.2.2 rec= TDMX 2.4/900 F.Port -Rud Spirit Gt. 3.4.3
Still no change for me with the updated files, nothing is being read, nothing to adjust.
PostPosted: Fri 11. Nov 2022 10:49:18
You should see a telemetry variables sent from Spirit unit first - in the Model - Telemetry screen.
All variables coming from unit should be visible there. If not, then the telemetry does not work at all.
For example RPM, Fuel and GPS Alt sensors.
PostPosted: Fri 11. Nov 2022 10:52:20
all telemetry is working fine, from hobbywing through the sprit.
PostPosted: Fri 11. Nov 2022 11:16:51
Then I guess the only thing that could affect this is EthOS version, used receiver and its firmware.
We have not tested TDMX receivers yet, so it is hard to say. It is possible these receivers require more recent EthOS version.
Users browsing this forum: No registered users and 34 guests
