It is currently Fri 22. Nov 2024 18:44:16
PostPosted: Thu 27. Oct 2022 21:14:35
Hi guys
Today, I did my first maiden flight with a new heli (DIABOLO SE) with my first Spirit GT FBL on board. :D
So far everything went fine except, that used capacity shows ten times too low.
RPM, voltage and current values are accurate.
Attached a short log.
I-motor-shunt does not allow the required correction. Any suggestions are welcome!
Thanks in advance and best regards
Daniel
BTW: Great FBL, I love it!
PostPosted: Fri 28. Oct 2022 9:47:07
Update
In contrast to the Futaba-Log in initial post, which states the real value for current (A), Spirit-Log shows current divided by 10.
See attachement.
Thanks for your support!
Best regards
Daniel
PostPosted: Fri 28. Oct 2022 9:53:14
thank you for your message.
We found the issue few days ago with some HW v5 ESCs and it was already fixed.
New firmware will be available possibly in next week. Or if you wish it sooner, we can send it to you.
PostPosted: Fri 28. Oct 2022 11:39:46
Hello
Great, I will keep an eye for the updates.
Thanks a lot!
Daniel
PostPosted: Thu 24. Nov 2022 11:15:57
Hello
Could you provide the estimated release date of the update, which will solve this issue?
Daniel
PostPosted: Thu 24. Nov 2022 11:33:03
We can make available the update to you immediately.
Official release date could be during 2 weeks.
PostPosted: Fri 25. Nov 2022 13:36:15
Hello
Two weeks (more or less ) will be fine!
I'm gona wait for this official release, thanks!
best regards
Daniel
Users browsing this forum: No registered users and 56 guests
