Hi Mattes61,
When I said I wanted to do this with a single cable, I wasn't talking about using a single cable for S-BUS and Telemetry, the only only Spirit unit that can do that is the Spirit GT via F.Port, and the R161 only support F-Port v2 and the Spirit GT wants F.Port v1.
But in this particular case, we're talking about a Spirit pro, and the R161. On the R161 Receiver, I already have S-BUS connected to the RUD port, however, the receiver also has a single wire S-Port output, but
like all other F-Sky compatible receivers, the S-Port is inverted. So on the Spirit Pro, I have to use the FrSky integration cable. The Integration cable "un-inverts" the signal, so that the Spirit Pro unit can read it. Unfortunately, all this makes for a lot of wiring, so I was hoping to get around all this wiring mess by pulling and already un-inverted signal off the receiver.
On some FrSky receivers and FrSky clone receivers, there are pads or locations on the receiver board where the original un-inverted signal is present. On the R161 it's here:
So I wired a cable directly to that pad, and tried to connect it directly to the SYS port to the signal pin first, and then the middle pin as suggested by the Admin, but in either case, no telemetry. The rest of the system works, and I got full control, but since there is no telemetry, there is also no integration, so I can't make any settings changes from the TX, the only way is to connect it via USB to a PC.
So for now, I went back to the original setup, with the Inverted S-Port and the Integration cable, but if someone knows of a better way, I'm open to suggestion. At this stage I can see 2 possibilities:
1. The un-inverted signal is not present on that pad as the photo suggests, although there are many other links on the web that suggest the diagram is correct,
2. The Spirit Pro does not support and un-iverted signal, and requires something "more", which the integration cable provides. This is the reason why I asked originally if the integration cable does "more" than just invert the signal.
