It is currently Sat 23. Nov 2024 3:44:46
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2, 3  Next
 Post subject: Specter V2 tail issue
PostPosted: Wed 19. Oct 2022 9:48:08
i use the Spirit RS in my Specter V2 with a GDW995 Tail Servo and 115mm blades. The tail turns slightly with the torque at pitch pump input at any rotationall speed (1400-2200 rpm). I changed all parameters (delay/revomix) but can't solve it completely. The issue went better with increasing the Revomix. Now the parameter is at 4. The delay is at 2. I talked in the RC Heli Forum about the issue and 2 other Spirit users wrote that they have the same Problem with another Specter V2 and a Protos 380. They tried also everything.
My tail mechanic slides super smooth and the Tail pitch sleeve uses almost the hole way of the rotor shaft. Controller is a YGE Aureus. When the Tail does not hold during hard Pitch input the Aerobatics can't be flown perfectly!
Maybe with higher values Revomix over 4 the issue could be solved!?
PostPosted: Wed 19. Oct 2022 9:53:19
please do not set higher RevoMix than 3.
Also please share your current settings.
Have you tried to proceed according: https://manual.spirit-system.com/index. ... DER_TUNING
I am sure it can be resolved easily, since there are many Specter helicopters that are working very well with Spirit.
Actually Spirit units were one of the first that were used even with Specter v1 at big events.
PostPosted: Wed 19. Oct 2022 9:58:59
Yes, it tried it with the proceeding list. But nothing helped. The issue was just minimized by increasing the Revomix as i wrote. If you know a pilot of a specter V2 where the tail still holds at hard pitch input, let me know the parameters. So i can try these!
PostPosted: Wed 19. Oct 2022 10:01:34
The issue is mostly in thr servo arm length.
Please share you settings and I will check them.
PostPosted: Wed 19. Oct 2022 10:04:14
Ok, i will measure it later at home.
PostPosted: Wed 19. Oct 2022 21:01:17
Hi, Servo arm length of the tail servo is 14mm. Before that i tried 16mm an the behavior was much worse.
PostPosted: Thu 20. Oct 2022 12:55:14
Tail Limits ar 130 (to tail boom) and 125. So i use nearly the full range with a little space at then end. I set the subtrim as it is discribed in the Specter manual. So the blades have about 3-5 degrees pitch.
PostPosted: Thu 20. Oct 2022 13:41:47
Thank you!
Could you also attach settings file please?
You can save it in the Backup tab - upper save button.
PostPosted: Thu 20. Oct 2022 15:02:13
Here you are!
Specter V2 Spirit RS.4ds [255 Bytes]
Downloaded 48 times
PostPosted: Fri 21. Oct 2022 16:31:12
Any ideas to solve the problem?
Users browsing this forum: No registered users and 49 guests
