It is currently Sat 23. Nov 2024 8:00:11
PostPosted: Mon 17. Oct 2022 17:29:36
Hello together,
i have big problems to setup my rescue function.
I have an opentx radio and switches assigned to gyro, banking (2 Position) and rescue (Momentary)
Bank 0 is my normal stabilization mode
Bank 1 is not assigned (Used for normal flight)
Bank 2 is my normal rescue mode
If i move my temporary switch to toggle rescue (assigned to activate bank 2), something happens, which i dont understand.
Normally the servos jump, if i toggle rescue in my normal flight mode (bank 1), but if the gyro settings are over 0% (Heading Hold)the rescue function doesnt work anymore. The diagnostic tabs shows then configuration (gyro sensivity) ?!? Please see pictures. If the gyro setting is 0% the diagnosis tab shows "activated" in blue.
Im not using negative gyro, this is assigned to a channel. My stabi mode ist also triggered in the diagnosis tab, also assigned to a channel.
Rescue works immediately, if i set the gyro gain to 0%.
Behaviour is the same with using internal Spirit GT gyro settings (No channel assigned to gyro)
My Gyro ist set to a potentiometer which is activated by a switch to adjust the gain. Range is from 0% to 80%. Set to 60%
Another behaviour is that the time (in my case set to 5,0 S) doesnt work. If i hold the momentary switch, rescue stays as long as i hold the switch. If i release it, my normal flight mode is directly back. So i have to hold it long enough.
What im doing wrong? Is there a general misunderstanding of the function?
Im searching since hours....didnt found any solution...
Need your help!
Greetings, Mario
PostPosted: Tue 18. Oct 2022 14:34:25
Hello again,
Nobody have an idea what im doing wrong?
Tested for curiosity the opentx template from this forum...
Same effects...Rescue dont work.
Thanks again for any feedback!!
Mario
PostPosted: Tue 18. Oct 2022 15:45:26
it is very hard to see if your opentx-Logic is correct or not - In my opinion all possible switch-positions have to be set correctly and no one has to be undefined - nothing may be open from the logic or a switch position - undefined states are to be avoided (this applies to banks as well as default values) otherwise there will be strange problems - just look at your outputs to see whether correct, defined values are always displayed - gyro has to go to the Example always be defined, it cannot be that the value is 0, but always in the range of 45-80% - In the worst case, you first reduce the complexity and then test again until your values or the the corresponding reaction is correct - I don't think that this is a Spirit problem, but rather a logic problem in the own programming of opentx/edgetx, i.e. a user problem - In the worst case I would advise you to set this up again in opentx/edgetx and test it again, you have to understand what you are doing -
PostPosted: Tue 18. Oct 2022 18:09:58
Hello Mattes61,
thanks a lot for your reply!
I know what you mean. I have my x9d plus since years and i tested a lot.
For me in this moment is only one point important. Maybe you can answer me this.
The manual for the gyro settings are not clear to me. (Maybe im too old)
The question is: If the value (Output) of the gyro channel is greater than "0", should the rescue function work?
Or should the gyro Output be < "0" on rescue mode.
Thats my problem. If the output is maybe 60%, my rescue function doesnt work.
In the channel screen, every output looks correct for me.
There is nothing overwritten or something. Im only testing in the moment. Maybe it is an understanding problem of the gyro function and im in the total wrong corner.
Interesting is that if i add a mix to the gyro output so that it is on -100% if i toggle in my case swith "h", the rescue function works.
In this forum there is somewhere a easys template for opentx in combination with spirit gt from a french poster. Nothing special. I tested this with a new model setting, but same effect.
Opentx on my radio is the last version.
Greetings, Mario
PostPosted: Tue 18. Oct 2022 20:07:25
Hello Mario,
the question is how you will activate rescue, there are three possibilities first negative gyro gain - If you have for example 55 % you are in heading hold mode, if you set then -55% you will get "rescue" if you have choosed negative gyro gain for "rescue" and a bank - rescue stands here for all possibilities (stablisation, rescue, rescue acro and so on) - the other possybility is to activate it by a dedicated channel and additional use of the benches with different settings -
The third possibility is independent on Banks and you can choose all sorts of"rescue" with different
channels for each function - good described in the manual:
https://manual.spirit-system.com/index.php?title=Configuration#STABI_TAB
look at it carefully and in detail, you can also play through it in demo mode in spirit settings to see which settings are possible -
Matthias
PostPosted: Tue 18. Oct 2022 20:10:17
sorry this picture could not be additional uploaded as I wanted -
here the one missing hardcopy plus an other additional window:
Matthias
PostPosted: Tue 18. Oct 2022 21:21:53
Dear Matthias,
thanks a lot for your explanation and your efforts!!
My channel settings are exakt the same as in your picture shown.
I have 3 banks over a 3 position switch accessable, first is stable normal, second is disabled (for normal flying) and the third bank is rescue normal.
I have "dedicated" to channel" selected in bank 2.
My momentary switch on the taranis "SH" is programmed to overwrite my bank select channel to 100%. So if i toggle my momentary switch automatically bank 3 is active and so the rescue function.
And then the problem occurs....
My Gyro Switch (2 position) for the gyro channel is set to 0 = 60 / 1= - 60%.
With this setting, im not able to activate rescue. If im in the bank tab, switching on the pc software performs without problems (bank screen switches all 3 positions) , but the rescue is in real at the heli not there. It is just in normal fly mode if i toggle the momentary switch.
Is it possible that my setting in bank 2 "dedicated to channel" is wrong. I saw something interesting: Sometimes if i toggle the momentary switch the setting "dedicated to channel" switched to negative gyro gain, although i stored the settings for sure.
In the moment i dont have any solution... I read the manual up and down...
Thanks again and please excuse my bad english (50 years ago i learned in school, not that easy for me)
I saw that youre also from germany.
Many thanks, Mario
PostPosted: Tue 18. Oct 2022 22:02:01
Hello Mario,
I think the problem is that you choose hegative gyro gain and selected by channel, this doesn't work ! Choose only one method, for example with a dedicated channel or only with a negative gyro value, then it will work! Don't use both methods at same time -
Matthias
PostPosted: Wed 19. Oct 2022 0:06:42
Hello Matthias,
your thinking sounds good. This could be the solution.
I will change my settings and test it.
If it works, i post a feedback.
Thanks again for your intense help!
Regards, Mario
PostPosted: Sat 22. Oct 2022 9:12:29
Hello Matthias,
your post was the solution!
Everything works now like it should.
As i thought it was an understanding problem.
The manual is very focussed on the negative gyro function.
An example like your photos would help people, who have never programmed a fbl system.
Thanks a lot!!
Greetings, Mario
Users browsing this forum: No registered users and 49 guests
