It is currently Sat 23. Nov 2024 8:10:21
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: RTH FlyAway
PostPosted: Tue 18. Oct 2022 11:20:52
More Logs.
Kraken 580 Position F not working after 5 flight 12 46 15102022.4dr [714.84 KiB]
Downloaded 25 times
Kraken 580 Flight 4th 11 50 15102022.4dr [659.56 KiB]
Downloaded 14 times
Kraken 580 3th Flight ok 11 30 15102022.4dr [710.99 KiB]
Downloaded 14 times
PostPosted: Tue 18. Oct 2022 11:21:55
More Log's.
Kraken 580 8th Flight Altitude Limit Function 2 with 01 Triggering without Fan 13 54 15102022.4dr [921.47 KiB]
Downloaded 16 times
Kraken 580 7th Flight ok without ESC Fan Altitude Hold Func 1 13 36 15102022.4dr [688.79 KiB]
Downloaded 14 times
Kraken 580 6th Flight Altitude Limit get crazy 13 05 15102022.4dr [852.14 KiB]
Downloaded 25 times
PostPosted: Tue 18. Oct 2022 11:53:09
thank you for the logs and details.
First from all I recommend to mount module at the tail boom. Module under CF boom is shielded and is also too close to the tail servo.
There is chance it can work also at this position but certainly all GeoLink functions will work less precisely. But it is hard to say if it will be noticeable or not.
GeoLink is measuring altitude mainly from GPS/GNSS so it is always better when it has no obstacles. Of course upside down it is worse, but still not that close main frame. For now you can leave it as it is.
After viewing the logs I can see you are engaging different functions. I will need also your latest settings file so I can see which functions they are.
It seems that when you say it is working you are engaging much less functions and less often.
Some two functions are engaged at the same time.
For this reason I recommend to try only single function and turn off the rest completely if you will fly next time.
I think that the problem is happening sometime when you are playing with a different functions.
Also I found that Altitude Limit is engaged mostly by normal mode when you program altitude from height in which model is.
In other flight you engage it with defined channel value.
Are you aware about this?
If battery is always repowered between flights then it does not matter which battery of flight it is. For Spirit unit, GeoLink it does not matter. For electronics it is better actually when it will warm up - especially when it is cold outside.
PostPosted: Tue 18. Oct 2022 12:07:29
Hello , thank's for the quick reply.
Also the Barometer in the SPIRIT GT is only in case , user don't have GL?
Will send you.
This is possible, because Position Hold I activated a lot of times with Altitude Hold. ( For Test's)
Correct, I was testing the Altitude Limit first by normal mode, and on the last flight I setup
the altitude by channel for Test. It's strange sometimes the Heli after activation goes up, and sometimes no,
but the function works even when the Heli not goes up after activating. We must found the way to make it more precisley the altitude meassure, also the function catch sometimes the Heli to early.
Even without Triggering activated.
I always by disconnecting the battery the Electronic is completly off, we have here around still 27º
PostPosted: Thu 20. Oct 2022 16:29:25
Hello together,
i thought also while for a solution to get rid off the fan vibrations.
I had this also very bad on my align RCE-BL100A. I saw a lot of vibration until a peak till 10 or so in the middle using the spirit diagnostic tab. Not good at all....
Its not only that mostly of the fans vibrate, secondly there wrong mounted to cool in an effective way.
In my opinion the only solution to get completely rid of the problem and as an improvement for air circulation you have to separate the fan from the chassis of the esc. Normally the fan is mounted directly on the aluminium case of the esc. This cant work!
First your vibrations of the mosten used crappy cheap fans (especially with ball bearings, yes they are bad for fans) will be transferred to the esc. And... the airstream cannot flow. It goes directly on the aluminium and blows back to the fan. Thats not a circulation. The webs in the esc are not deep enough to let the airflow go to the sides.
I think that the manufacturs of the esc dont offer a good solution, because of costs.
My solution is seen on the attached photos.
Also, if your fan vibrates a lot, its for sure out of balance. These fans are mostly the cheap ones.
If you want to buy a real good fan take a look at my pictures. This fan is absolutely quiet, have vapo bearings and it is balanced. Its good to see, how many bore holes are necessary to get good balance. (I have no connections to this manufactor, its only from my experiences with fans and is an example - Around 10 Euro at ebay)
Take care with the nice looking aluminium fans, mostly offered for rc car motors. They look nice, but i never saw a balanced one and the run often at 28.000 Rpm. (Way to much) And they use around 0,65A at 7,5V. You should use a fan which is declared with 5V and around 0,5W and 10.000 Rpm. (30 x 30 x 10mm) This should have no impact on your bec.
If you have a very bad fan, its possible to balance it, but it takes time. My method is: Separating it from the unit, power it with a separate cell and use soft silikon cables. Take your smartphone and search for an vibration analysis tool app. Im using "SmartTools" on android. Set the vibration tool to its maximum sensivity. Let the fan run and lay it on the surface of the phone. Lay a finger on it, but dont press. You can easy see the vibration. Choose some isolation tape as an example and cut pieces lets say 5x5mm. Put it on one place of the fan (Round zone of the fan to the maximum outside) Take a look on the vibrations. If its worse move your tape in little steps until you find the place where the vibrations are at lowest. Sometimes you have to use more tape pieces over the other ones. Take a drill (Only a holder with drill) and remove very little material on the opposite side of the tape. Remove the tape and test again, until you are satisfied. Be patient, it can take a while ;-) Nothing for people without time and patience....
On one photo to see, this is the original crappy align fan balanded as good as possible for me.
My mounting is handmade of 1mm CFK. It is silver, cause it is foiled. Only for the bling bling ...The rubber anti vibration balls balls are cheap and you can get them on ebay. They have a diameter around 10mm. Airflow is superb. Add on weight is around 5 g.
I dont have a 3D printer, but this would also work i think.
With this configuration i have absolute no vibrations on the diagnostic tab in the spirit software.
I thinks its not a good idea to fly without fan, especially on hot summer days. That would be to risky for me.
Maybe here in this forum are also people who likes to fumble and have fun with building by yourself.
Greetings from germany
Mario
PostPosted: Thu 20. Oct 2022 16:31:37
Only 2 photos added.
PostPosted: Fri 21. Oct 2022 15:24:06
I dont get it why the spirit relies on vibration to detect airborn. I would assume vibrations are much higher in flight. So the threshold might be too low. Also if the throttle channel is -100 there is no chance that thing is in flight, or not?
Users browsing this forum: Bing [Bot] and 63 guests
