It is currently Sat 23. Nov 2024 7:53:31
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
PostPosted: Thu 22. Sep 2022 18:09:38
I am using telemetry with a YGE 65 on a Spirit GT what do I configure for the « sensing divider » ?
Got the latest version but number can’t be 21, in the spirit menu it says divide number of poles by 2 and I think it is max 12 that the menu accepts.
Here is the motor specification :
* Motor Setup:
- POLES 42, KV 200. - RATIO 1:1
PostPosted: Thu 22. Sep 2022 19:12:09
From the news section...
Updated Governor:
Support for new Goblin RAW 420.
Sensing Divider has range up to 32.
PostPosted: Thu 22. Sep 2022 20:22:01
Updated Governor:
Thanks, i do remember but it still does not enable me to input that value. I migrated a existing configuration from another heli to the GT.
Here are my 3 config files using windows 3.4.3 and to make sure I re-flashed again 3.4.3 and i am limited to 14 poles using YGE. (I tried using HW and still limited at 14)
Added on sep 24th: i tried in the demo mode and still limited to 14.
2raw420.4ds [255 Bytes]
Downloaded 32 times
1raw420.4ds [255 Bytes]
Downloaded 27 times
0raw420.4ds [255 Bytes]
Downloaded 28 times
PostPosted: Mon 26. Sep 2022 12:09:35
Hi Thomas,
I understand by not seeing you answer that this make take time to correct.
I have not Maiden this heli yet, can you explain how the pole are used to calculate the speed ? I could at a minimum put 10 poles (around 1/2 of the 21) to start and multiply by 2,1 and get the real speed ?
I don’t know how the pole are used to get the speed reading.
PostPosted: Mon 26. Sep 2022 12:14:38
there is nothing to correct.
It is enough to update both firwmare and software to the latest version and it will work.
You can set Sensing Divider to 32 without any problem.
ESC brand is not playing any role there.
PostPosted: Mon 26. Sep 2022 12:56:55
Hi Thomas,
Your are showing the Governor menu in your reply.
I am using the « telemetry menu » with YGE where you ask for number of poles and divided by 2.
Is that information in telemetry used to return the RPM ? Or for the other features, I will use the GT feature of logging playback.
I am not using the gov at the moment
PostPosted: Mon 26. Sep 2022 13:00:25
Ah, this was not clear previously.
Parameter is shared between these windows. You can set the value in Governor menu too.
If the problem was only in the Telemetry window, then please download and install the Spirit Settings 3.4.3 software once again.
I hope all will be fine.
PostPosted: Mon 26. Sep 2022 13:06:30
Ok will try
PostPosted: Mon 26. Sep 2022 22:13:12
Hi Thomas,
it works now in Telemetry at 21 for Pole/2
I had 3.4.3 downloaded on 2 computers, i did as you said and dowloaded again and it worked. I checked my other computer and it was still blocked at 14, after download it's resolved on this one as well.
Do you have a explanation why the first 3.4.3 download did not work ? Did you change something ? I would like to understand for future changes.
Thanks !
PostPosted: Tue 27. Sep 2022 18:09:25
I think there was something changed afterwards...
Matthias
Users browsing this forum: Bing [Bot] and 48 guests
