urgno wrote:
hello
wow, thats a big mechanic
only one thing in my humble opinion,
the geolink is in a very bad place
under the heli frame the geolink cannot have a clear view of the sky
and maybe also the barometer will get some strange vortex down there
ofc when you will mount the fuselage that will be better
maybe then you could attach the geolink directly to top of fuselage
Hey, thanks for your input!
The geolink is mounted on the bottom to make use of the Laser sensor, drilled a hole in the fuselage right beneath it. It acquires its 12 satellites in <5 seconds.. I already thought about mounting it on the fuselage, but can't test this in current state as the flight behavior is way too unstable to risk the expensive, >600 working hours fuselage
