It is currently Sat 23. Nov 2024 7:59:43
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue 13. Sep 2022 18:09:34
Hello, Yesterday I tried the harddeckheight variable and the fixed harddeckheight.
In one of the settings, I can't remember which one, the heli kept climbing. Even after pressing the switch in the middle position, that is
neither 1 nor 2, the heli continued to climb and did not observe the maximum height limit. (It was set to 120 meters) My question: Are the rescue functions for Geolink 1 and V2 or only v2. Had to switch off the motor of the heli because I could hardly see the heli due to the height it had reached. He fell to the ground. The Geolink used to be a Geo ling (now consists of many individual parts). Since I still have 2 helicopters with the
Geolink, I don't dare to use it at the moment. Doubts upon doubts!!! :( :(
PostPosted: Tue 13. Sep 2022 18:16:48
that is very sad.
All functions are same for V1 and V2.
Maybe there was a stabilisation or rescue mode active. Can you send me your settings file please? I can check.
Normally you can turn off any feature immediately and there is no delay between on/off condition. So there must be something else in the play, but I guess it is all related to settings.
PostPosted: Tue 13. Sep 2022 19:32:29
Hello, I don't think I can send the data anymore, I can't read the geo link anymore, it's totally destroyed.
PostPosted: Tue 13. Sep 2022 19:46:45
Hello sorry, it just occurred to me, I have the same settings in the other heli as well. I will send the settings data tomorrow.
First of all, thank you very much for the support.
PostPosted: Tue 13. Sep 2022 20:30:43
Thank you too. I am sure the problem will be sorted and the problem will be found.
GeoLink is not needed if the settings are still there.
PostPosted: Wed 14. Sep 2022 14:03:25
Hello here are my settings that I could see. Will send as photos, because I do not know exactly what data you need exactly.
PostPosted: Wed 14. Sep 2022 16:10:34
Here are the rest of the photos
PostPosted: Wed 14. Sep 2022 17:14:41
thank you very much!
I will need rest of the settings unfortunately - all are saved in the file.
You can easily save it from the unit in the Backup tab.
Then attach it here and I will see completely all parameters.
PostPosted: Wed 14. Sep 2022 17:33:43
Hello here is the correct file.
t-rex 500 spirit dateien.4ds [255 Bytes]
Downloaded 23 times
PostPosted: Sat 17. Sep 2022 16:35:54
I checked your settings and found that nearly everything looks good.
But one thing that could cause problems is that you have F: Stabi mode in the Special functions but in the Stabi tab you have Selected by Channel.
So your configuration contain two different engaging for rescue function which can cause that you can achieve quite unexpected condition depending on how your other banks are set and your model can for example fly away with Rescue function engaged even that you think you disengaged it.
So please remove F: Stabi Function from Channels. Then you can check all functions on the bench and verify that it is all doing what you expect. It is very important to not leave anything assigned if not used.
