It is currently Fri 22. Nov 2024 0:54:50
PostPosted: Mon 12. Sep 2022 21:38:23
This is happening with Radiomaster Zorro and Radiomaster TX12 MK2 running EdgeTX and the Spirit 3.3.2 LUA (which is what is linked at http://manual.spirit-system.com/index.p ... stallation)
I was able to fix it by adding EVT_VIRTUAL_NEXT_PAGE and EVT_VIRTUAL_PREV_PAGE to the if statements at the end.
Code:
local function run(event)
  if event == nil then
    return 2
  elseif event == EVT_PAGE_BREAK or event == EVT_RIGHT_BREAK or event == EVT_VIRTUAL_NEXT_PAGE then
    selectPage(1)
  elseif event == EVT_PAGE_LONG or event == EVT_LEFT_BREAK or event == EVT_VIRTUAL_PREV_PAGE then
    killEvents(event);
    selectPage(-1)
  end
  fields = pages[page][1]
  local result = runFieldsPage(event)
  refreshNext()
  return result
end
I believe all that's really needed are the EVT_VIRTUAL_xxx_PAGE checks after skimming the documentation for OpenTX and EdgeTX:
https://luadoc.edgetx.org/part_iii_-_op ... ual-events
https://doc.open-tx.org/opentx-2-3-lua- ... ual-events
PostPosted: Mon 19. Sep 2022 11:33:05
many thanks for your message!
Please try our new integration scripts. There is direct support for RM-Zorro now.
Users browsing this forum: Bing [Bot] and 35 guests
