Hi Tomas,
here you get additional information, I logged the RPM over my transmitter, here you see that the
RPM values are all valid and do not deviate as much as in the SpiritSettings log - if the transferred values were wrong, then I would also have such utopian RPM values - I suspect that an error may have been made during data processing/data evaluation (diagram in SpiritSettingsLog) - the correct RPM values were displayed and logged in my remote control -
I think that's easy to correct, maybe you didn't notice that until now -
A note on the diagram, the last value logged is the first speed level (approx. 1800 rpm) for landing, the data log stopped after pressing Throttle Cut - therefore no end with speed "0" (UMin) !
Many greetings
Matthas
