It is currently Sat 23. Nov 2024 10:04:06
PostPosted: Sun 10. Jul 2022 21:14:50
Is there any reason I cannot use port CH0 on a Spirit GT for dual power supply ?
Thank you
 Post subject: Re: Spirit GT Ch0 Port
PostPosted: Mon 11. Jul 2022 9:25:08
I think the only reason is that you need the ch0 for a servo :mrgreen:
other than that, is the perfect place to inject a backup power supply
( in addition to aux 1 / aux 2 )
PostPosted: Mon 11. Jul 2022 9:33:40
Many thanks for your reply. Just what I wanted to hear. I am trying to free up channels for GeoLink functions.
PostPosted: Mon 11. Jul 2022 10:00:47
CH0 port has nothing to do with GeoLink. You can use this port for anything.
GeoLink functions are controlled by channels of your radio transmitter.
PostPosted: Tue 12. Jul 2022 4:10:49
I had the back up power supply cable plugged into Aux 2 on the Spirit Unit. I am using the dedicated GeoLink Channel option to trigger the GeoLink features I want to use - it seems more straightforward and frankly I didn't understand how triggering by engaging the Stabi function would work in practice. For this reason I wanted to maximise the number of free channels available. What I am unsure about is if I had the back up power supply plugged into the Aux 2 port on Spirit, would this mean I could not then use Aux 2 channel 7 in my transmitter to trigger a GeoLink function (or Stabilisation function for that matter). Hence the question about moving the back up power supply to Ch0.
Many thanks
PostPosted: Tue 12. Jul 2022 6:52:37
Hi
no - the port Aux2 is just a connector on the Spirit unit. it has nothing to do with your radio (TX/RX) channel. you can use this channel for "F:" functions anyhow (wether something is connected on the unit or not). this is, btw, the same for all servo/bec connectors on the Spirit unit.... ch0-ch4, aux, thr have nothing to do with your radio channels.
cheers
Michael
PostPosted: Tue 12. Jul 2022 9:50:00
I am most grateful for your explanation. A lot clearer now and of great help to me.
Many thanks
Michael
Users browsing this forum: Mattes61 and 19 guests
