It is currently Sun 29. Dec 2024 17:57:00
[ 3 posts ] |
tkosier
Posted: Sat 23. Apr 2022 0:56:01 |
After a single six minute flight, when using the Advanced Flight Viewer, I get 5 logs, each being about 1 min 20 seconds long. Is there a way to get a single log of 6 minutes? My Spirit/Jeti12DS records a single log of 6 minutes. Thanks Thomas
Posted: Sat 23. Apr 2022 15:31:08 |
flight logs are recorded based on vibration level. If it is over 4% it starts recording. Only in case your model has super low vibration level it might cause such issue. Can you verify what level you can see during flight?
I guess you are trying with blades on in a real flight.
tkosier
Posted: Sun 24. Apr 2022 21:37:05 |
Thank you for responding
Appears my issue was too much vibration. Was using the log to follow up on some odd flight behavior. The logs revealed a vibration level of 80 magnitude! Replaced a bad bearing, rebalanced blades and tried again. On the bench with no main or tail blades, I ran a three minute test. The vibration magnitude was 16 magnitude and the entire run was recorded properly. Installed blades and ran a 6 minute hover in my front yard. The entire six minutes was recorded in one log. The vibration during the hover was recorded at 50 magnitude. All other parameters were recorded perfectly and identical to the log that was recorded by the Transmitter. Thomas
[ 3 posts ] |
Users browsing this forum: No registered users and 2 guests |
