It is currently Fri 27. Dec 2024 16:58:00
PostPosted: Mon 18. Apr 2022 22:34:39
I have a question about the lua-script for the integration (openTX) -
Works this without any changes for edgeTX 2.6/2.7 or must it be different programmed for edgeTX ?
If the lua-script for OpenTX doesn't work when will we get then an working lua-script for edgeTX ?
Is here something planned ?
Matthias
PostPosted: Wed 20. Apr 2022 20:23:28
Afaik there's no changes to the lua code on edgeTx. I expect the script will run fine.
PostPosted: Thu 21. Apr 2022 11:12:52
Hello jjuk,
thanks a lot for your reply !
I didn't know if anything would change and I definitely wanted to be sure that it worked -
I have posted this also under general discussion and there mithoss has approved that by the change to edgetx works all flawlessly !
I am very :D !
Matthias
Users browsing this forum: Levend and 2 guests
