ZeXx86 wrote:
if unit is pulsating, then you can try to fix the problem by using Recovery mode.
Please start the software, select Recovery mode. It is very importnat to select correct COM port in the Connection tab - Device list.
Then go to Update tab and power up the unit. Then click at the Flash button. Then flashing should start immediately.
Is flashing working?
Here is step by step guide:
http://manual.spirit-system.com/index.p ... ing_FailedReference connection I try again.
All the previous operations were carried out smoothly according to the guide. However, after pressing the software upgrade button and downloading the latest firmware, the gyro software displays "no response" and there is no response. (the blue light on the top still pulsates and does not flash rapidly)
I waited for half an hour, but the software didn't respond. Now I forcibly shut down the software (it turns gray)
The top has no change except the blue pulse at the top.
