It is currently Sat 23. Nov 2024 14:26:14
PostPosted: Wed 05. May 2021 10:57:57
I'm trying to set up integration with my TX using this guide :http://manual.spirit-system.com/index.php?title=Spektrum_Integration
I have all the required hardware.
When I go into the Telemetry menu I cannot find "Text Gen" - what am I doing wrong?
PostPosted: Wed 05. May 2021 12:05:46
Hi
Last firmware in the radio ? And the rx ‘s ?
PostPosted: Wed 05. May 2021 12:12:41
Ok, I figured it out - Text Gen was removed on Airware v2.07 and above but it should display automatically, it doesn't..
PostPosted: Wed 05. May 2021 18:05:10
Hi i have the same problem with :
- dx9 2.08
- 4649T V1.1.10
- spirit 3.2.2
PostPosted: Wed 05. May 2021 18:36:44
Hi again...
I find a solution in a Deutch forum :
- activate "priority monitor" in telemetry/settings and leave the menu screen
- with the roller go to the last telemetry page "priority monitor"
- move Rudder stick to the right and Aileron stick to the left and hold for over 2 seconds
- roll back one time (to the left) and Spirit settings appears :)
It works for me
PostPosted: Thu 06. May 2021 12:21:33
It is not necessary to activate the "Priority Monitor" to display "TextGen".
But in the "Priority Monitor" you can see immediately that "TextGen" has been activated.
The following works fine for me:
- Spektrum DX9 with AirWare 2.08
- all my Spirit Pro have the firmware 3.2.2
--> 1 Heli with HW Platinum HV 160A V4 with Spektrum SPM4649T Quad Race Serial Receiver with Telemetry
--> 1 Heli with HW Platinum 120A V4 with Spektrum SPM4651T SRXL2 Remote Serial Receiver with Telemetry
PostPosted: Sun 04. Jul 2021 20:08:55
pachy wrote:
Hi again...
It works for me
I did have the same problem and didn't believe that this would solve it, but indeed it does. It works exactly as you described it!!! :o
But I wonder what exactly is going on here? Is this the way it is intended? Maybe Tomas can clarify?
Also it would be nice to know if it would be possible to utilize the new "Forward Programming" menu that comes with latest DX Firmware instead of the Textgen menu. When trying to use it, the DX8 (in my case) says "connection failed" after a few seconds.
Thanks in advance!
PostPosted: Sun 20. Feb 2022 17:11:23
Hi, just for information, i have install Airware 2.09 and everything seems work fine :)
Users browsing this forum: mainstreet and 36 guests
