It is currently Fri 22. Nov 2024 0:32:23
[ 3 posts ] |
Uplate
Posted: Tue 25. Jan 2022 2:19:46 |
From the manual.
Place GeoLink at a flat, aligned horizontal surface anywhere at your model in order to get a precise reference. (for example the Spirit unit)
My model has raked landing gear for extra tail blade clearance. Therefore when sitting on the skis the fbl is angled down towards the nose.
Is it still OK to set geolink on top, or do I need a perfect bubble level and shim gear to precise level?
Thank you.
urgno
Posted: Tue 25. Jan 2022 10:36:38 |
usually I use the "zero temporarily" button
put geolink on top of the motor ( if the motor is upside and big enough like in a 600-700 heli ) or on top of the spirit unit then press "zero temporarily" on geolink screen then you mount the geolink trying to align it with the 0° / 0° shown by the program
this way you will be sure that the geolink will be aligned with the 0° of the helicopter
Uplate
Posted: Tue 25. Jan 2022 16:54:30 |
Thank You for confirming. I just wanted to make sure it was level with heli and not true bubble level. I did read the temporary set in the manual.
[ 3 posts ] |
Users browsing this forum: No registered users and 37 guests |
