It is currently Thu 16. Jan 2025 3:14:21
PostPosted: Mon 10. Jan 2022 23:23:55
I tryed to change for example the collective pitch parameter with the channel 9 of the transmitter. I can see that the value in the channel mapping table is changing between -100% and +100%, but on the heli there is always the same amount of max collective pitch. I tryed the same with the rescue pitch, but it is the same behaviour.
What do I have to do to change parameters with the receiver?
Dieter
PostPosted: Wed 12. Jan 2022 10:35:04
values in the Spirit Settings will remain same. This value is always loaded from memory that was saved the last time.
But when you are changing channel value, this will overwrite the value.
So if some parameter is assigned in the Channels, it will work immediately.
How you figured out that the value was not changed? Were you looking with opened software?
PostPosted: Wed 12. Jan 2022 18:42:06
as I mentioned above, I assigned the P:collective Pitch and the P:rescue collective Pitch and I watched the swashplate during I changed the values, but it has no effect at all.
Dieter
PostPosted: Wed 12. Jan 2022 20:18:47
nach dem ändern im Sender, dort auch auf ,,speichern,, gedrückt ? wen nicht wird auch nichts verändert.
Gruss Gery
PostPosted: Wed 12. Jan 2022 22:07:41
Yes I did, otherwise if you don't save it, the next time you turn on the transmitter there wouldn't be any assignement. And I tryed it a lot of times, everything should be okay, but it doesn't work, at least for the to values, maybe it will work with the other values but I don't have the possibility to prove that.
Dieter
PostPosted: Thu 13. Jan 2022 17:31:28
Please note you have to close the software if you want to see any change in parameter.
Otherwise values are set by software.
PostPosted: Sat 15. Jan 2022 23:13:52
I don`t have the spirit connected to a PC, what else?
Dieter
PostPosted: Fri 21. Jan 2022 0:30:14
is there someone who can adjust collective Pitch with a transmitter channel, and if there is, can you tell me how you made it?
Dieter
PostPosted: Fri 21. Jan 2022 8:15:40
could you share your settings please?
I am afraid but it just works normally. It is only important that no software or integration is running and that unit status LED is not flashing (which signaling that unit is still in the configuration mode).
PostPosted: Fri 21. Jan 2022 10:39:54
Perfect, now it works, thank you.
After power on the heli I always went into the receiver menu of the transmitter to set some values or looked for the correct settings, but obviously if I leave the menu the spirit still stay in the configuration mode. Now I just turned on the heli and it worked.
Dieter
