It is currently Sat 23. Nov 2024 11:28:18
Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
PostPosted: Mon 10. Jan 2022 22:53:55
Hello 10x,
so did I understand that, maybe I have it written a bit unclear -
BR Matthias
PostPosted: Tue 11. Jan 2022 15:40:16
problem should be resolved now. Please check the firmware 3.3.4 from today. The problem was with GT units while using telemetry.
This was issue with the firmware. We are very sorry for the troubles.
PostPosted: Tue 11. Jan 2022 16:05:19
Wonderful Tomas, thanks for all your hard work on this.
I will test this tonight when I'm back from work...
Cheers, Mike
PostPosted: Tue 11. Jan 2022 16:30:50
Hello Tomas, thank you very much for your great effort to solve the problem!
Unfortunately, at the moment I only have a Spirit II with ESC telemetry (YGE) installed in my Align 450 L Dominator, the Spirit GT used for testing will probably find its way into the XLPower 520, I don't have an ESC for it yet, but it will become a Hobbywing 120V4 - that means I cannot test with telemetry on the GT at the moment, I have to rely on my colleagues -
Technically I would be very interested in what it was in the end, maybe you can say something about it, that would be nice - if not via the forum you can also tell me by PM if you want - I'm looking forward to the tests of the two colleagues -
Many greetings
Matthias
PostPosted: Tue 11. Jan 2022 16:41:23
So it appears the fix is working!
Telemetry is enabled, I can see the telemetry info on my DX9 and importantly, I retain control of the model if I unplug the 4651T!
There still seems to be a ~0.5 second gap in control the first time the main RX is unplugged but I don't think this is a serious problem... I can live with it :)
Hopefully I can test in flight this weekend if the weather allows. I'll update here once I've done so.
Thank you again Tomas and Team Spirit. You have made me a very happy customer, and I plan to use the Spirit on all my models going forward.
The next one will be a friend's Henseleit TDR2 8-)
PostPosted: Tue 11. Jan 2022 16:50:18
Hello Mike,
well done ! 8-)
I'm really curious what you can report after your flight - :)
Many greetings
Matthias
PostPosted: Tue 11. Jan 2022 19:38:58
I've successfully flashed 3.3.4 (1/11 version) and based on my preliminary tests on the SpiritGT with a 4651T, everything seems to be working fine with and without telemetry enabled. More testing to come relating to redundancy with multiple receivers but... This is excellent! Thank you Tomas!!
-Eric
PostPosted: Tue 11. Jan 2022 21:24:06
Hello everyone !
I have tested my configuration ESC YGE, Spirit II with firmware 3.3.4 from 11.01.22 -
I have to say bad news ! It doesn't work stable - Framelosses were resettet for example 4 to 0 - Rpm's were showed 30000U/min but motor is not running ! Amperes and volts are shown very high values 3xx V, 500 A but motor isn't running -
This mainly happens when I plug in or unplug the 4651T connected via the Ail pin, but unfortunately also not so comprehensible with the 9747 - if either the 4651T alone or the 9747 alone is plugged in, the whole thing is stable, with the 9747 plugged in via sat2 - I have attached a few pictures and the FlightLog, which then also contained a receiver signal lost, although I had plugged in at least one satellite -
After the first positive post I was euphoric, now rather depressed -
Many greetings
Matthias
PS. I don't know if I can upload all the photos, maybe it will work -
spirit-log-2022-01-11-194749.pdf [74.45 KiB]
Downloaded 42 times
PostPosted: Tue 11. Jan 2022 21:26:42
Now the pictures, if it will work...
PostPosted: Tue 11. Jan 2022 21:30:06
Next pictures, sorry it doesn't work in an other way...
Users browsing this forum: No registered users and 31 guests
