It is currently Mon 25. Nov 2024 14:15:23
Posted: Tue 04. Jan 2022 15:55:32 |
Thank you, but what value you can see for Geometry 6°. I am not asking for degrees.
It could at least reduce the shaking.
zino
Posted: Tue 04. Jan 2022 16:31:58 |
The value of geometry is 69.
zino
Posted: Tue 04. Jan 2022 16:40:03 |
I must reduce it? And if geometry is less than 6° is mot a problem?
zino
Posted: Tue 04. Jan 2022 19:20:12 |
Thank you Matess61 for your reply. I will try to replace maybe the dambers with not so rigit. Thanks
zino
Posted: Tue 04. Jan 2022 20:35:51 |
Hi ZeXx86. Do you think the value of geometry is very low? Thid can make servos to shake? Thanks
zino
Posted: Wed 05. Jan 2022 7:52:46 |
Hi. If you please have time tell me abour the value of geometry. Thanks for the time you are spending for me.
zino
Posted: Wed 05. Jan 2022 9:25:27 |
Hi. I would like to ask somethink for rudder as well. Why we must put rudder at 0°? Always most of helis need a bit of possitive pitch about 6-7° towards the tail boom in order rudder to keep center. Maybe am wrong? Please inform me. Thanks
zino
Posted: Wed 05. Jan 2022 12:45:36 |
Posted: Wed 05. Jan 2022 13:15:08 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 568 Location: Germany
Hello Zino! In my setups I do it as follows, the control horn on the servo is set at right angles either to the housing of the servo or to the tail linkage, depending on where it fits better - then I adjust the length of the linkage so that I set a bit of pitch to the right approx. 8 mm, if you fold both tail rotor blades in one direction (backwards) - then it is tested in rate mode whether the helicopter turns away or whether it roughly stops (hovering), depending on which it is readjusted - I know this is old school, but I relieve the control loop in headinghold mode - others do it differently, I do it that way -
Best regards Mattes61
zino
Posted: Wed 05. Jan 2022 14:03:59 |
With all my flybar models i do exactly the samige procedure like you. So i will do and with my fbl model. Thank you very mauch.
Users browsing this forum: No registered users and 7 guests |
