It is currently Mon 25. Nov 2024 14:49:38
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: TREX 700 NITRO
PostPosted: Tue 04. Jan 2022 15:55:32
Thank you, but what value you can see for Geometry 6°. I am not asking for degrees.
It could at least reduce the shaking.
PostPosted: Tue 04. Jan 2022 16:31:58
The value of geometry is 69.
PostPosted: Tue 04. Jan 2022 16:40:03
I must reduce it? And if geometry is less than 6° is mot a problem?
PostPosted: Tue 04. Jan 2022 19:20:12
Thank you Matess61 for your reply. I will try to replace maybe the dambers with not so rigit. Thanks
PostPosted: Tue 04. Jan 2022 20:35:51
Hi ZeXx86.
Do you think the value of geometry is very low? Thid can make servos to shake? Thanks
PostPosted: Wed 05. Jan 2022 7:52:46
Hi. If you please have time tell me abour the value of geometry. Thanks for the time you are spending for me.
PostPosted: Wed 05. Jan 2022 9:25:27
Hi. I would like to ask somethink for rudder as well.
Why we must put rudder at 0°? Always most of helis need a bit of possitive pitch about 6-7° towards the tail boom in order rudder to keep center. Maybe am wrong? Please inform me. Thanks
PostPosted: Wed 05. Jan 2022 12:45:36
Any reply?
PostPosted: Wed 05. Jan 2022 13:15:08
Hello Zino!
In my setups I do it as follows, the control horn on the servo is set at right angles either to the housing of the servo or to the tail linkage, depending on where it fits better - then I adjust the length of the linkage so that I set a bit of pitch to the right approx. 8 mm, if you fold both tail rotor blades in one direction (backwards) - then it is tested in rate mode whether the helicopter turns away or whether it roughly stops (hovering), depending on which it is readjusted - I know this is old school, but I relieve the control loop in headinghold mode - others do it differently, I do it that way -
Best regards
PostPosted: Wed 05. Jan 2022 14:03:59
With all my flybar models i do exactly the samige procedure like you. So i will do and with my fbl model. Thank you very mauch.
Users browsing this forum: No registered users and 12 guests
