It is currently Mon 25. Nov 2024 0:56:49
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
PostPosted: Mon 03. Jan 2022 14:23:35
ZeXx86 wrote:
For throttle hold you should set -100% in your radio. This should correspond to 0%. But only if your channel travel is set to a lower percentage. Because SBUS output from TX16S is different than for Futaba.
The Channel monitor on my tx shows -100% when I hit throttle hold.
But spirit software showes -13%.
I am now confused of what to expect.
Should I expect 0% on screen?
Sent from my Redmi Note 8 Pro using Tapatalk
PostPosted: Mon 03. Jan 2022 14:31:30
Yes, you should expect 0%.
This mean that your throttle channel was still not adjusted correctly and has default range.
PostPosted: Mon 03. Jan 2022 14:41:54
Wow.. how have I missed it !?
I actually fly like this 3 other helis.
Can you point me to the place on the manual where it is discussed?
Thank you
PostPosted: Mon 03. Jan 2022 15:53:33
Hello Lee Jordan,
I think you should reach "0" in the spirit settings in the diagnostic tab !
You should increase the value for the throttle hold setting (from -100 to -87?) until the exact value "0" is reached in the diagnostic tab (throttle) - this is only a matter of setting in the remote control, not in the FBL -
Best Regards
PostPosted: Mon 03. Jan 2022 16:39:49
Mattes61 wrote:
Hello Lee Jordan,
Best Regards
Thank you.
I will do that.
Anyway, I did the test flight and heli flies real nice regardless of this throttle hold issue.
Cheers
Users browsing this forum: No registered users and 70 guests
