Mattes61 wrote:
Hello Lee Jordan,
what about your channel monitor in TX16S ? Are the values every time at throttle-hold the same if you get the -13% or the other values you mentioned (Idle up1/up2) ?
Maybe you can deactivate the spirit governor temporarily and then look at the Diagnostic tab how the throttle channel behaves ?
You also said that the two models in programming are nearly the same
How do these two models differ in terms of programming?
Maybe there is a relevant difference in the logic here, you would have to compare them against each other, maybe some error has crept in - maybe you can set your OpenTX file here, maybe someone can then double-check - here are some experienced users in the forum who are very familiar with OpenTx programming -
Personally, I don't think that this is primarily due to the Spirit FBL, I rather think that the problem is to be found in the programming of OpenTx - I would also like to be taught better, only at the moment I would have no other explanation -
On the other hand, you could double-check with the other FBL (loaded with the respective other model) whether the same behavior is shown or it is then different -
If the behavior is identical, then it is definitely due to the programming -
Many greetings
Mattes61, thanks for your reply.
I now connected the 505 model to the computer to se the values and I found that it also has only minus 13% on throttle hold.
This model flies on a daily basis.
So,
I took the blades off the Raw700 and checked for the first time if the motor works as I want and specifically if the throttle hold cuts the motor and it is running as intended.
In summary,
The model is flyable and will have its maiden flight done today.
I will investigate why this minus13%.
You suggested the FBL governor may ne the issue.
I'll check that.
Sent from my Redmi Note 8 Pro using Tapatalk
