It is currently Sat 23. Nov 2024 18:05:49
PostPosted: Thu 02. Dec 2021 5:49:07
I noticed in the online manual SRXL wiring the author are using a SPM4649T receiver: http://manual.spirit-system.com/index.p ... e=SPM4649T
The SPM4649T is an SRXL receiver (not SRXL2); however, the wiring example supplied are connecting SRXL2.
Using the SMP4649T as an example is a mistake in the online manual.
Correct SRXL wiring: http://manual.spirit-system.com/index.p ... D_RECEIVER
SRXL2:
Spektrum AR6610T (and others in this range)
Spektrum SPM4650T (Limited distance telemetry)
Spektrum SPM4651T (Full distance telemetry)
Spektrum SPM6747 (No telemetry)
SRXL:
Spektrum AR9020 (SRXL #1 "language")
Spektrum AR7700 (SRXL #2 "language," same as AR8010T, AR9030T and so on..
Spektrum SPM4650T
File comment: Quick wiring SRXl/SRXL2/Hobbywing
File comment: Correct SRXL wiring - all pins in RUD
File comment: Example of SRXL2 wiring with an SRXL receiver used
PostPosted: Thu 02. Dec 2021 8:55:37
You are not right.
SPM4649T is actually not SRXL receiver, although some are calling it that way.
It is using old protocol known from DSM2/X satellites.
Where you found in the manual it is SRXL2?
As far as we know everything is correct in the manual. This receiver is older than SRXL2, but newer than SRXL1 receivers.
PostPosted: Fri 03. Dec 2021 6:37:57
As Tomaz said, the 4649T outputs RRP (remote receiver protocol) as spoken by the legacy remote receivers (also called sats).
And it was the first Spektrum receiver that also takes serial input to send data back via telemetry according to the Bi-Directional SRXL protocol:
https://github.com/SpektrumRC/SpektrumD ... 20SRXL.pdf
To my knowledge, only the 4649T speaks that.
Other old SRXL stuff like the AR8010T only output SRXL but do not take SRXL input.
And the new SRXL2 series communicates via that new protocol in both directions ...
chris
PostPosted: Fri 03. Dec 2021 8:14:41
chris
Yes, that is right. But still SPM4649T has nothing common with SRXL receivers. So it shouldn't be called SRXL receiver. But it was hard to distinguish and from marketing point of view to better promote.
PostPosted: Fri 03. Dec 2021 15:21:44
And that's exactly my take on it. Sorry if I couldn't state that clearly enough. I wanted to say something like
It's neither RRP nor SRLX nor SRLX2. It's its own family. Rather call it 4649T than anything else.
Even if you are exact and name it "bi-directional SRXL", the next guy will drop the "bi-directional" and call it SRXL again :)
PostPosted: Mon 06. Dec 2021 4:25:23
chris
If the SPM4649T outputs RRP why doesn't it work in place of a remote receiver(ignore the minimum voltage limit)?
PostPosted: Mon 06. Dec 2021 13:42:08
Actually it works. There is no difference in channel transmission data, except AIL pin has bidirectional output for telemetry and also it has different connectors.
PostPosted: Mon 13. Dec 2021 5:19:03
So that we are on the same page...
- I noticed Thomas asked where I found it was SRXL2. I stated SRXL, not SRXL2
- Does this mean that the 4649T are being connected to a Spirit FBL like an SRXL2? So the manual are correct?
- Lastly, the 4649T will transmit telemetry - battery voltage, RPM and everything else as needed?
Hope to hear from you guys :)
PostPosted: Mon 13. Dec 2021 8:31:31
Yes, manual is correct. Wiring is basically same as for SRXL2, but not identical. Different cables are needed as described in the guide.
If your ESC has telemetry support, then yes. All telemetry data are then transmitted to your radio.
Users browsing this forum: No registered users and 25 guests
