It is currently Sat 23. Nov 2024 18:12:06
 Post subject: Wizard setup
PostPosted: Thu 11. Nov 2021 3:52:07
Question for support. Once the gyro setup is completed via wizard, to achieve maximum pitch of 10 degrees and minimum of -1degrees....will adjustments to linkages effect the 6 degrees geometry setup
 Post subject: Re: Wizard setup
PostPosted: Thu 11. Nov 2021 9:30:28
Yes, it will affect everything and is not recommended.
Instead you should use settings in your radio to set pitch from +/- 10° to 10/-1°. So adjusting pitch curve is the only correct solution.
PostPosted: Tue 16. Nov 2021 4:17:44
Wow..good I asked. As I fly scale I prefer a linear curve -1 or 0 to 10 degrees. Thanks for the reply.
PostPosted: Tue 16. Nov 2021 6:00:33
So there is no way a linear pitch curve from 0-10 and linear throttle curve 0 -100 can be achieved via the spirit 2 system ?? Is that correct ??
PostPosted: Tue 16. Nov 2021 8:35:48
Yes, there is way that I described in the previous post.
Simply set pitch curve from 0 - 100% to achieve pitch range from 0° to 10° - instead of -100% to 100% for +/- 10°.
But initially mechanics must be set for full range. So that when servos are in the center position, there must be 0° between main blades.
Any other settings will lead to imprecision. This is common for all FBL units.
