It is currently Sat 23. Nov 2024 14:10:07
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Fri 29. Oct 2021 16:18:26
i have a newly built Goblin Fireball 280 Havok with all stock components, except YGE ESC.
Problem is a very strong tail shaking, right after liftoff which is getting more and more till the whole Heli is shaking.
- Tail is running smoothly, checked that 3 times
- Tried with SpiritRS and new bought Spirit GTR, settings are "Goblin 280" from the Spirit First setup wizard. I also tried with rudder delay at 0 (viewtopic.php?f=20&t=2147&p=25120&hilit=goblin+fireball#p25120) but nothing changes.
Anybody a tip?
Tino
PostPosted: Sat 30. Oct 2021 18:49:16
I think you should reduce your headgain (cyclic) about 5 points - I had the same problem and at first I thought its a tail problem but it wasn't -
If you look exactly you would see a shaking in elevator and ail axis and therefore reduce headgain -
BR
PostPosted: Sat 06. Nov 2021 15:33:45
BR
Hi Mattes,
tried this today, the shaking is better, but I have a continuously tail wag (left and right), which is getting better the higher the RPM.
I also went through the whole Spirit Tuning Guide, but nothing seems to makes it better.
Tino
PostPosted: Sat 06. Nov 2021 17:17:10
Hi Tino,
my tailgain is not very high, I can say it only on spektrum stettings -
In Normal Mode: 47 %
In Stunt 1: 42 %
In Stunt 2: 40 %
I can not say rpms but percentige in the radio (Spektrum)
Normal Mode: 60%
In Stunt 1: 68 %
In Stunt 2: 75 %
Its not very high rpm, I know, but for my flying style good enough -
I hope this will help you -
Best regards
Matthias
PostPosted: Sat 06. Nov 2021 17:27:18
Hi Matthias,
thanks for your settings, could you eventually share your spirit settings? Saved 4ds File?
Would be great.
Tino
PostPosted: Sat 06. Nov 2021 18:26:25
Hi Tino,
here you get my settings from the Goblin Fireball -
I hope that will work for you -
Best regards
Matthias
Spirit_PRO_Goblin-Fireball_Bank2_040721_Sett.4ds [255 Bytes]
Downloaded 29 times
Spirit_PRO_Goblin-Fireball_Bank1_040721_Sett.4ds [255 Bytes]
Downloaded 33 times
Spirit_PRO_Goblin-Fireball_Bank0_040721_Sett.4ds [255 Bytes]
Downloaded 35 times
PostPosted: Sat 06. Nov 2021 18:37:35
Thank you very much :D
PostPosted: Mon 08. Nov 2021 16:19:22
Mattes61 wrote:
Hi Tino,
In Stunt 1: 42 %
In Stunt 2: 40 %
Normal Mode: 60%
In Stunt 1: 68 %
In Stunt 2: 75 %
Best regards
Matthias
first I should ask you to excuse me for jumping in you thread with a additional question..
Hi Mattes61,
How did you configure in Spektrum the tail gain so they change when you go from normal to stunt 1 and 2 ?
Envoyé de mon iPad en utilisant Tapatalk
PostPosted: Mon 08. Nov 2021 18:20:23
Hi Pking,
this is very simple - If you choose in FM-Gyro an switch named flightmode.
In systemsetup you have an flight mode setup then you can define an dedicaded switch 1 only, in my case "switch A" and for the Hold Mode "switch H" -
In the Flight Mode Setup you have now a defined switch for flight modes and for Hold - Check here whether the switching states change as expected, if this is not the case, then the checkbox must be set to "1" -
Have you done that you can go back to Gyro - In Gyro you an set now for each flight mode an appropriate value.
You can also use the flight mode for an different pitch curve, expo or rotational speed (in %, for example 65, 75, 82)
I hope this will hepl you !
Best Regards
Matthias
PostPosted: Sat 13. Nov 2021 1:50:03
No matter the FBL used the Fireball requires reasonably low tail gain. With a Spektrum TX I'd start at 30.
Users browsing this forum: No registered users and 35 guests
