It is currently Sat 23. Nov 2024 4:15:48
 Post subject: Spektrum NX6, NX8, NX10?
PostPosted: Sat 16. Oct 2021 19:28:11
Hi - new to Spirit! Just wanted to confirm that the Spektrum NX6, NX8 and NX10 allow for full integration.
I notice that these transmitters are not listed here: http://manual.spirit-system.com/index.p ... ntegration
Thanks!
PostPosted: Sat 16. Oct 2021 19:43:13
I have three systems, one on a DX9 one on a NX6 and one on a NX10. No issues...
T
PostPosted: Sat 16. Oct 2021 19:44:43
T
Thank you!
Looking to move from the DX9 to NX10 … how is the NX10? Good for “forward programming”?
PostPosted: Sat 16. Oct 2021 20:04:41
I wasn't a fan of the forward programing but it has grown on me. Being able to program the smart ESCs from you transmitter is nice. Wifi is cool too. You might want to check out the IX12. But I still love my DX9..
PostPosted: Sat 16. Oct 2021 20:08:32
Thanks, appreciate the feedback. Yes, DX9 is a great radio…
PostPosted: Fri 29. Oct 2021 19:04:02
I have an Spirit II firmware 3.3.2 an SRXL2 Receiver 4651T firmware 2.4.4 and an ESC YGE 65LVT - My transmitter is an NX10.
Text Gen isn't available anymore and I tried Auto-Config, there are some windows but the value of RPM isn't right - I have set the Poles and the gear-ratio in the ESC and in the spiritII - I dont know if that's right - but also I have no integration window ? What have I done wrong ?
All cables for ESC-Connection (Sat1) and SRXL2 (Rud-Port and Ail-Pin) receiver are made correctly
In the second test I hadn't made no auto-config and choosed ESC and Flightpack but nothing changed -
What can I do ? You have got integration and how have you done it that it works by you -
Thanks a lot for your help !
PostPosted: Sun 31. Oct 2021 12:54:35
I had found something out, if you have an YGE and want to have telemetrie (right rpm) you should put the poles and the gear-ratio into the YGE-Sorftware (for Governor or Governor-store) then you should set in spirit telemetrie the pole pairs to 1 and the gear-ratio also to 1 ! Then the rpm works !!
The other problem I have not solved (Integration) -
Maybe somone could help me what I have to do in my spektrum NX10 ?
You to have said that the integration works for you (Boltor and Tgalo) can you please help me ?
Thanks a lot in advance !
PostPosted: Mon 01. Nov 2021 8:43:54
ESC settings should be never configured in the radio.
It can be set in the ESC itself OR in the Spirit unit.
If you will set it at both, then both will do the same calculation which will result in much lower RPM.
PostPosted: Mon 01. Nov 2021 12:17:41
Hello Tomas,
thank's for your reply !
Tomas it would be very kind if you can say me something about the missing integration page in the nx10 - have you tested some NX10 or NX8 if the integration will work ? I have no blank side in the telemetrie screen if I scroll with the roller -
In terms of YGE Controller:
Would it be possible to change the manual that when you take govenor or govenor-store you should configure the poles and the gear-ratio in the YGE and do for the telemetry in the spirit the gear-ratio and the pole pairs set the both values to "1" that the rpm shows right up in the telemetry screens ?
I have testet it with an optical device (stroboscope) that the shown rpm in the telemetrie screen is right -
Thanks in advance
PostPosted: Mon 29. Nov 2021 12:19:39
we have Spektrum NX radio and tested the integration and telemetry. Everything is working.
It was enough to update to the latest radio firmware and it is working out of the box.
So the issue was just old firmware in the radio.
When entering to the integration menu, just move and hold sticks closer to each other and then you will be able to roll with the roller to the right in Telemetry screen. And from this point integration menu is fully opened and active.
It look like the integration experience is the best with NX radios as it has a bigger fonts and better display. Much better than with iX series.
Users browsing this forum: No registered users and 38 guests
