It is currently Sat 23. Nov 2024 19:31:10
PostPosted: Tue 12. Oct 2021 1:30:29
I just finished a Nitron build and the governor is either not working or seriously over speeding. Today was the first flights and I started hovering in normal which has a curve of 0-25-40-50-65. I switched to idle 1 which is supposed to be 2000 and the RPM display showed over 2400. I don’t have a tach but it was well north of 2000. I am using the Spartan sensor split so that the signal goes to the middle pin of the RPM input and the power/ground go to aux 2. I’m using 2 active magnets and the sensor divider set to 2 with a max RPM of 2200. The curve is a flat 91. I moved everything from a Kraken 580n with the only change being the use of 2 active magnets. The log is clean as far as I could tell but I didn’t check until I got home not realizing Spirit clears the log on power up unlike Vbar that keeps it. I verified the sensor shows “inactive” over both magnets.
I’m using a new GT with a Jeti Rex 7. The throttle goes to channel 1 on the Jeti rx which I believe is the same way it was setup on the Kraken but I’m not 100% positive. I’m out of ideas at this point.
 Post subject: Re: Nitro governor issue
PostPosted: Tue 12. Oct 2021 1:35:24
The throttle servo has to be connected to the GT, otherwise the GT can not control the throttle.
Sent from my SM-G991U using Tapatalk
PostPosted: Tue 12. Oct 2021 1:43:46
From manualImage
PostPosted: Tue 12. Oct 2021 15:48:17
Thanks, that fixed it.
PostPosted: Tue 12. Oct 2021 16:41:30
You're very welcome!
Users browsing this forum: Bing [Bot] and 34 guests
