It is currently Fri 22. Nov 2024 0:39:01
PostPosted: Wed 06. Oct 2021 15:21:02
(warning, extreme geek subject :-)
Just curious, Tomas: Have any tests been done to determine the exact rotor phase?
Most of us know that gyroscopic precession is 90 degrees, but heli swash plates do not deliver the control action at 90 degrees, the blade deflection begins earlier (strating a 180 degree arc), apexes at 90 degrees, then continues.
So it has been suggested that the actual phase lag on our helis may be closer to 80 degrees, and that the FBL unit is compensating for this so we don't notice it. (and presumably it will be a bit different owing to blade weight, headspeed, etc.)
Kasama Faifa and Dune, Shape S8, TDR, Raptor E700 gasser, Trex 500, Beam Avantgarde and E4 SE
Users browsing this forum: No registered users and 46 guests
