It is currently Sat 23. Nov 2024 4:01:00
 Post subject: info about GT altitude
PostPosted: Fri 17. Sep 2021 10:22:02
hello
is possible to see what altitude is detected from spirit GT
when doing tests on bench ?
thank you
PostPosted: Fri 17. Sep 2021 11:59:22
there is a minimum of vibration necessary so the GT/GTR is detecting the heli as flying (i.e. mechanics running *without* all blades worked for me)... but then you can go into diagnostics & advances logging features. if you log the altitude there you could see it (will be 0 unless you move it around a bit... mine showed 0 on bench and ~1m when lifted above bench).
cheers
Michael
PostPosted: Fri 17. Sep 2021 13:36:28
i was hoping there was a real time indication like in geolink status screen
Users browsing this forum: Bing [Bot] and 48 guests
