It is currently Sat 23. Nov 2024 20:47:36
PostPosted: Tue 14. Sep 2021 11:25:38
Hello !
I have a theoretical question - let's assume I already have a set flybarless system with spectrum receivers (satellites) -
What happens if I just want to change the receiver on this basis, for example to Futaba SBUS - let's leave the changes
with regard to the direction of travel and any level change at the inputs. Do I have to do a completely new setup with this change
or is it just enough to change the things listed at the beginning, such as level change, direction of movement, channel assignment, etc.?
Thank you for your answers !
Mattes
PostPosted: Wed 15. Sep 2021 8:55:31
it is enough to:
1. Change Receiver type
2. Set your radio - channels and directions correctly according Diagnostic tab.
Nothing more is needed. It must be flying in the same way if your new radio is configured in the same way as the old one.
PostPosted: Wed 15. Sep 2021 17:07:31
Hello Tomas,
thank you for your answer !
Yesterday I got a Futaba T 16IZ and I hoped that it will work ergonomicaly for my hands but it didn't and I have to sent back the Transmitter - The distance between the switches were to small for my fingers (Sh-Switch (Throttle Hold) and the other side of the front plate...) -
So at this moment there is unfortunately no chance for Futaba Transmitter :cry:
Users browsing this forum: Bing [Bot], mainstreet and 32 guests
