It is currently Sat 23. Nov 2024 20:52:03
[ 6 posts ] |
Tgalo
Posted: Sat 11. Sep 2021 22:12:49 |
Two questions, in the diagnostic page my throttle bar doesn't move but the throttle works. I have a linier curve set. Also, can I add expo from the transmitter? Thank you
10x
Posted: Sat 11. Sep 2021 22:15:13 |
Has the throttle been assigned a channel?...Yes you can add expo to TX...
Tgalo
Posted: Sat 11. Sep 2021 23:22:07 |
I have created a new model. Haven't gone into channel assign in my radio. Using Spektrum. On the diagnostic screen, it says "unassigned"
10x
Posted: Sat 11. Sep 2021 23:33:40 |
You need to go into the general tab and receiver, Have you set up the receiver type yet?, Hit channel button and assign throttle to channel 1... If this is a new setup it is best to use the wizzard to setup.....
Tgalo
Posted: Sun 12. Sep 2021 10:19:50 |
Ahh yes, I see that now. But the throttle button is grayed out. I'm using a standard receiver and picked PWM.
Posted: Wed 15. Sep 2021 9:00:10 |
you can't see Throttle channel with PWM connection, because throttle signal is not coming to the Spirit unit at all. Throttle is connected to your ESC, but unit can't know the signal value with this connection. In other words you do not have to change anything regarding throttle in the Spirit unit. Only your radio is controlling it.
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 26 guests |
