It is currently Sat 23. Nov 2024 20:41:55
PostPosted: Thu 02. Sep 2021 20:20:39
are there problems with 2S Lipo battery supply directly on the Spirit 2? With me, the Nickservo is smoked out on the ground.
Best regards
Marek Bischof
PostPosted: Thu 02. Sep 2021 20:51:31
I am using a 2s Lipo for several hundred flights on the Spirit 2 and the Spirit GT.
No problems so far.
PostPosted: Fri 03. Sep 2021 3:58:18
Best regards
Marek Bischof
Hi
Spirit units is made for 3-15V and can deliver power to 5HV servos.Maybe your servo whas a low voltage
servo 4,5-6V or there whas something wrong whith the servo.
Latjo
PostPosted: Fri 03. Sep 2021 7:58:40
Spirit is not doing anything to voltage you will feed to the servos.
So there should be technically no way how a FBL unit or receiver can damage the servo if you will set recommended frequency and neutral impulse.
Users browsing this forum: mainstreet and 42 guests
