ZeXx86 wrote:
return to home programming maybe not worked for you, because connection was unstable with GeoLink. I believe new firmware will fix it.
During next week, we will be releasing update with improvements. Also Altitude Limit and Automatic Rescue will have time that you describe for ascending.
Today some Flight Test again with FW 3.3.2, and now the GeoLink works perfectly,
I test the Function ( Rescue Automatic) and work's perfect, I reduce the minimum altitude to 5 Meters,
and now the Heli when it's comes down to the pregrogrammed altitude , he climbing to around 25 Meters,
and at the same time nice levelled on duration around 1.5 Seconds. Also with this Function now working perfect , it's very difficult to crash
a Heli, specially for beginner. The only I not see in the softwarwe the windows to adjust the Rescue duration.
Congratulations very good Job well done.
So now I will continues with fine Tune the Position Hold, the Heli starts to make a little circle ,
and not hold the altitude.
And It looks that the programming for the Home Position via Transmitter switch still not going.
I think the best it's really, by start up the Motor that this position must storage as Home Position,
because it is to much trouble to take everytime when Flying the Notebook plus you need Internet
for the Map, also the Risk that the Heli Flight away is very High, example if Fail Safe is storage,
in another place ( MAP) where you Flying actually, the chance is big that the Heli Flight away.
Also it is a must, that the Home Position must be refresh, everytime by switch on the Heli before Flight,
this is very inportant.
After this I start to Test the Autolanding !
