It is currently Sat 23. Nov 2024 20:38:52
[ 2 posts ] |
lpaelke
Posted: Thu 12. Aug 2021 22:09:35 |
I would like to use a Spirit RS with a Gasser with an RCEXL CDI Ignition. Can I get the RPM signal for the governor directly from the ignition? Either with a Y-cable from the Hall-sensor or from the tachometer outpout signal from the CDI? Or do I need an extra sensor?
Thanks,
Lutz
lpaelke
Posted: Sun 12. Sep 2021 9:48:39 |
OK, since there was no answer, I tried it myself. A Y-cable from the Hall-sensor of the ignition to the Spirit-RS worked in principle, but the signal was way to noisy.
So now I use the Hall-sensor from the Jeti MRPM Hall EX (just the (replacement) sensor, not the whole MRPM EX module) with 2 magnets mounted on the cooling fan. This works fine.
[ 2 posts ] |
Users browsing this forum: mainstreet and 50 guests |
