It is currently Sat 23. Nov 2024 23:06:21
PostPosted: Wed 28. Jul 2021 9:16:06
Last weekend I start to Install and setup the GeoLink on my third Heli, I come to the step “Mounting inclination”, but I saw the values going up and down very fast, therefore was impossible to adjust the Level, I wondering why because my first two Helis on setup doesn’t see this .
By the way the Hobbywing ESC 200Ah cooling Fan was a little bit noising , and I decided to switch it off, surprisal the values going to work normal, I will try with Ferrite ring’s to evolve the cooling Fan cable , and see what happens. Very strange that an Fan make interference to the GeoLink.
PostPosted: Wed 28. Jul 2021 11:56:51
It has been posted many times that HW fans can cause problems. If you want to use a fan use a
Sunon Maglev Fan.
PostPosted: Wed 28. Jul 2021 15:30:47
Sunon Maglev Fan.
Thanks for the Tip, but is not easy to find the same size like the Original Hobbywing !
Sunon These are PC Fans. A little bit to big.
Anyway actually with 30º , the ESC Runs around 52º it's ok.
Castle Creations ESC Runs over 120º !
PostPosted: Wed 28. Jul 2021 17:37:07
i've used Sunon MagLev fans too on all my Hobbywings as long as I had them... Sunon's do exist in many different sizes and rpm ranges for different electronics purposes - perfect fit for all Hobbywings do exist. as they do not cause such a lot of vibrations, they did never cause any trouble on any of my helis - but HW stock fans did.
Ciao
Michael
cheers
Michael
PostPosted: Wed 28. Jul 2021 18:06:09
Ciao
Michael
Hi, sounds good, have you any Model reference?
PostPosted: Wed 28. Jul 2021 18:27:11
.... unfortunately not - too long ago I bought the last one. but just go to sunon.com and browse their online catalog for format/thickness/voltage + rpms you are looking for.... that's how i found all of them. many of them are directly available via Amazon.
cheers
Michael
Users browsing this forum: Bing [Bot] and 65 guests
