It is currently Sat 23. Nov 2024 23:08:24
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: GT initializing
PostPosted: Tue 20. Jul 2021 19:14:08
No, you can find it in the Diagnostic tab - Advanced Flight Logging.
PostPosted: Tue 20. Jul 2021 19:20:12
Thanks for quick reply Tomas, so only in the pc set up software? Turned it off will let you know how it goes...
PostPosted: Tue 20. Jul 2021 21:45:57
As Tomas suggested
Turned Advanced flight logger off and it seemed to work, tried several times to initialize, at different time intervals (30 sec. - 30 minutes)and all attempts worked as normal.
so yes, could have been the advanced flight logger.
this is just my findings so far but I thought I would share.
PostPosted: Tue 20. Jul 2021 22:47:58
Thought it was ok with flight logging turned off, but just needed a double battery to initialize after standing for 1 hour....
PostPosted: Wed 21. Jul 2021 0:08:52
Same as 10x
tried initializing again after sitting for a couple of hours and had to do the double battery connection to get it to initialize.
PostPosted: Wed 21. Jul 2021 7:41:18
Can you attach settings please?
Unfortunately we can't replicate it in any way - tested with around hundred of GT units now - even that all units were without a power for over day.
PostPosted: Thu 22. Jul 2021 0:10:05
here are the settings from my GT unit on my Synergy N5C nitro machine.
thanks
N5C settings.4ds [255 Bytes]
Downloaded 36 times
PostPosted: Thu 22. Jul 2021 21:16:43
Flew tonight, still had to double connect the rx power plug from life battery. Produced another log....
The log keeps coming up with " Main Loop Hang Occured" and "Backup Oscillator is Used"
Can you tell me what do these entries mean Tomas?......
Also to add that i can not see these problem logs on the jeti DS12, I can only see them
with the pc Spirit settings software...
Regards Adrian
PostPosted: Mon 26. Jul 2021 10:36:47
Regards Adrian
both of the errors are sign that something was not good at all. The first one is quite important and I recommend to verify wiring.
The second one mean that the unit was partially damaged sadly (the most common is electrostatic hit from a finger). But it can be still used normally, because it has backup part. Anyway this is not related to the issue discussed in this thread.
Can all affected pilots can let me know what receiver are you using please?
PostPosted: Mon 26. Jul 2021 11:34:00
Can all affected pilots can let me know what receiver are you using please?[/quote]
Hello Tomas, Jeti REX3 receiver for me...
Regards Adrian
Users browsing this forum: Bing [Bot] and 57 guests
