It is currently Sat 23. Nov 2024 22:24:24
Ahmad.Kassem
Posted: Fri 16. Jul 2021 10:13:49 |
Hello
I am facing problem with the USB connection to my spirit GT, the unit is disconnecting from the windows app several times during the setup, them I will need to exit the app and enter again to make it work, also whenever I go to Advanced Flight Viewer and then I load a flight log then the app will exit when the loading is 100%, so I am not able to view any flight logs.
Regards Ahmad
Posted: Fri 16. Jul 2021 10:18:30 |
can you please describe your wiring?
Is it possible to disconnect everything that is not really necessary from the unit?
Ahmad.Kassem
Posted: Fri 16. Jul 2021 10:27:57 |
hello
my wiring is as follows:
1- receiver is Radiomaster R161 connected to RUD port and using F.Port Protocol 2- Geolink connected to SAT2 3- Hobbywing ESC telemetry cable connected to SAT1 4- Hobbywing ESC RPM output connected to PIT pin 5- Hobbywing ESC throttle connected to AUX1 ( I am using ESC BEC) 6- Remaining cyclic and rudder servos connected to CH1 to CH4
Regards Ahmad
Ahmad.Kassem
Posted: Fri 16. Jul 2021 10:55:58 |
I disconnected the GeoLink ang esc telemetry cable but the problem remains.
Posted: Fri 16. Jul 2021 11:06:55 |
Thank you, do you have any other USB cable to try?
Ahmad.Kassem
Posted: Fri 16. Jul 2021 11:08:29 |
Unfortunately no, this is my first spirit unit.
Posted: Fri 16. Jul 2021 12:09:08 |
could you please retry with everything disconnected, except BEC? If also this will fail, we will send you new USB injterface for trying. We never experienced similar issue, so I dont know where the problem could be.
Also trying other computer can be very helpful.
Ahmad.Kassem
Posted: Fri 16. Jul 2021 14:39:26 |
hello
I have removed the unit outside the model and I connected only the BEC and USB cable and the unit got disconnected after 15 minutes, second time i have connected also the receiver and now the unit disconnects after 5 minutes, however always when I load a flight log the app closes when the loading percentage reaches 100%.
Regards Ahmad
Ahmad.Kassem
Posted: Fri 16. Jul 2021 15:29:57 |
I am noticicing that this is only happening when i connect the receiver.
Sent from my SM-N976Q using Tapatalk
Ahmad.Kassem
Posted: Sat 17. Jul 2021 14:47:18 |
Dear ZeXx86
Any update?
Users browsing this forum: No registered users and 57 guests |
