It is currently Sat 23. Nov 2024 22:53:07
PostPosted: Mon 07. Jun 2021 7:21:17
Should be a quick one to answer...
Just bought a few things from the online Spirit FBL shop and forgot to add the Telem Uni Cable :(
Can a normal JST-RX adaptor still be used with the Spirit Pro and Spirit V2 just with the red (middle) cable removed?
Hope to hear from someone..
PostPosted: Tue 08. Jun 2021 21:29:42
Yes, you are right.
Red wire disconnected. Otherwise it could burn unit.
PostPosted: Sat 03. Jul 2021 11:40:44
Having same problem here. I'm switching the ESC and just need Telem Uni. Did it work for you Anton?
What is then a difference? Telem Uni seem to have some PCB inside, so is it not needed at all?
PostPosted: Mon 05. Jul 2021 7:56:42
Nope, you don’t need the bought one. Home made works perfectly fine.
It looks like a pc board, however just a 3 in, two out.
Recap, just snip the positive wire - all good.
PostPosted: Thu 15. Jul 2021 22:32:41
Thanks, I did it and it works fine.
Users browsing this forum: Bing [Bot], gfyss and 55 guests
