It is currently Fri 22. Nov 2024 1:08:02
PostPosted: Mon 12. Jul 2021 22:50:54
Running GT on my Oxy4max with f.port on a r-xsr reciever and all the integration stuff seem to work and is alot faster and more responsive, but the governor gain menus are gone.
The first page in the "special.lua" script only shows frequency and min and max on the throttle channel. Not the governor stuff.I am running the latest lua script from the spirit website.
It works fine on my spirit 2`s and pros over s.port
PostPosted: Sat 04. Sep 2021 22:07:20
Am I the only one with this behavior
Got a second GT and it has the same behavior.
PostPosted: Mon 06. Sep 2021 10:28:31
are you sure you are in Bank 0 when loading this page?
PostPosted: Mon 06. Sep 2021 11:04:17
Hi.
Yes 100% sure. The last page says bank0
And if I select bank 1 or 2 the script says no parameter available : bank 1
I have lots of spirit pro and spirit2 units with s.port intigration where this works as it should.
I have two spirit GT with xsr over fport.
Both behave the same as in the video.
Other integration functionality seem to work as before (except a lot faster:)
https://www.youtube.com/watch?v=OO6WB7q6ays
here is a video. First run of the script in bank2 then in bank0
PostPosted: Sat 11. Sep 2021 16:26:26
Hi
I was just able to confirm that the bug does not show up when I connected the gt over s.port and sbus. with no inverter. as soon as I revert to f.port the bug is back
PostPosted: Thu 16. Sep 2021 7:34:07
thank you for the details.
We are working on fix that should be available very soon.
PostPosted: Thu 16. Sep 2021 9:02:15
Awesome! Thank you
PostPosted: Fri 08. Oct 2021 14:48:25
It seems like next week we could have firmware that will resolve the issue. We will let you know.
PostPosted: Tue 12. Oct 2021 13:51:33
please download new script version https://www.spirit-system.com/dl/opentx ... 3.2-en.zip
I hope it will work fine now.
Also we added support for X-Lite radios.
PostPosted: Thu 14. Oct 2021 12:17:55
Great!
Thank you
It seem to be working now :)
Users browsing this forum: No registered users and 48 guests
