It is currently Thu 21. Nov 2024 23:22:03
dogbreath
Posted: Tue 29. Jun 2021 15:15:07 |
Joined: Wed 20. Jan 2016 20:23:36 Posts: 17 Location: DFW Texas
Received the Spirit GT unit yesterday. Downloaded the 3.3.0 software and connected the GT. After setting EXBUS protocol and my servo speedsI I tried to update to firmware 3.3.1 . Flashing appeared to work but after flashing the unit has fast blink and is not found by the software. Tried a number of times to re-flash (recovery) and the app closes while trying to download the firmware--just after the green bar finishes filling. Re-loaded app and drivers, no change. Tried new cable, no change. Any ideas?
edit: Tried to update a Spirit II (3.2) to 3.2.2 and it wasn't recognized either. Firmware recovery also failed same way. I had powered both units with a 2S at 7.2 volts so battery seems fine. Windows 10 ver. 2004. Just updated to 21H1, no change. Re-ran install as administrator, no change.
edit 2: Stuck a Spirit Pro on there and it updated to 3.3.1. A second Spirit II (3.2) was not found. Loaded software on newer computer (win10 21H1) and same problems. Won't even see the Spirit Pro.
Looking in device manager (on the newer computer) under PORTS(COM & LPT) the events tab says "Device USB\VID_10C4&PID_EA60\0001 requires further installation."
Any thoughts on what to try next?
thanks, Dan
_________________ Synergy 516, 556 stretch, 696.
Posted: Tue 29. Jun 2021 17:24:36 |
it seems that for yet unknown reason Spirit Settings version 3.3.0 has problems on some computers. If you have still old version 3.2.2, can you try to install this software and flash firmware 3.3.1?
Or you tried to update with Spirit Settings 3.2.2 initially?
NitroRex
Posted: Thu 01. Jul 2021 11:58:49 |
Joined: Wed 09. Jun 2021 22:09:08 Posts: 15 Location: Schweiz AG
Habe das gleiche Problem, alles auf neustem Stand, jedoch findet die Jeti und auch der Computer das GT nicht. Gibt es ein Link um es mit der alten Software zu versuchen? Sehr schade, 5 Wochen warten, und jetzt ist es hier und funktioniert nicht
Posted: Thu 01. Jul 2021 18:24:37 |
NitroRex
Posted: Thu 01. Jul 2021 18:53:42 |
Unfortunately it does not work either, the GT flashes very quickly, if I want to connect it then 3x slowly and then again quickly ---- no connection .... still have an old "spirit" that is no longer recognized on the Pc
Posted: Thu 01. Jul 2021 19:19:25 |
Please make sure to plug power supply right before plugging power supply. Unit should start flashing and then you can click at the Flash button. So that unit is not powered during software startup. This could help you.
eg183100
Posted: Fri 02. Jul 2021 10:35:40 |
I have the same. tried with 3.2.2. software to flash 3.3.1. flashes very quickly. application is at 0% and the unit does 3 blue flashing, then pause, then 3 flashes again, etc, etc
dogbreath
Posted: Fri 02. Jul 2021 15:19:47 |
Sorry, I do not have a copy of 3.2.2 software to install and test. If you tell me how to get a copy I'll remove 3.3.0 and install 3.2.2 and see if it still works. It worked before; all my Spirits were on 3.2.2 before this upgrade.
thank you, Dan
NitroRex
Posted: Fri 02. Jul 2021 17:51:30 |
a link for the old software would help many where the 3.3.0 does not work ....... I have 5 Spirit and also the GT, I cannot get the GT to run, and the others no longer work on the PC: - (
Posted: Tue 06. Jul 2021 22:31:32 |
Users browsing this forum: No registered users and 0 guests |
