It is currently Sat 23. Nov 2024 21:43:27
PostPosted: Fri 25. Jun 2021 22:32:21
I want install a Spirit 2 on my TDR with an old YGE 90HV. On the Wiki I saw that I have to connect the RPM Signal line to the RPM Pin but where I have to connect the brown/orange (they both are connected with each other) wire? Can I connect them to EXT Pin?
Is there a possibility to connect the RPM signal to the Spirit RS that I can use the RPM signal to display on my JETI DS-14II main screen?
Happy flyings
PostPosted: Sun 27. Jun 2021 22:02:31
Nobody have an idea?
Happy flyings
PostPosted: Mon 28. Jun 2021 8:23:12
Hi
It is the red cable from esc program (rpm)going to the rpm pin on spirit,the brown cable is going to - on some pin on fbl,dasent matter whitsh -pin you choses.The orange is for yge progcard.
Then you can see the rpm in Jeti tx telemetry.
I think you looking at the connection for Vbar,its different from Spirit.
//Latjo
PostPosted: Mon 28. Jun 2021 12:20:30
Thank you, so I can connect the brown (ground) cable to the EXT Pin under the RPM Pin!
Happy flyings
PostPosted: Mon 28. Jun 2021 13:18:19
No this pin is for jeti sensors,the E1 port -pin or anyone else exept for sys port can you use.
You can allso connect the -(ground)to the becs- or if you use a 2s battery to -pole,the - ground is the same in
the whole system.
//Latjo
PostPosted: Mon 28. Jun 2021 14:03:13
Thanks for the answer, I thought that EXT Pin I can not use, this was my general question here!
I will use one of the ground from the satellite ports, this I don't need, the rest is totally used because of external BEC and I don't want to use a V-Cable Adapter.
Happy flyings
PostPosted: Mon 28. Jun 2021 16:03:21
OK
Your Welcome
Users browsing this forum: No registered users and 35 guests
