It is currently Sun 24. Nov 2024 0:50:40
 Post subject: Firmware
PostPosted: Fri 21. May 2021 16:50:12
Where do I find the firmware to update my Spirit Pro to 3.2 ? It is currently showing 3.1.0.
 Post subject: Re: Firmware
PostPosted: Fri 21. May 2021 18:32:55
I have the same problem.
New to Spirit systems and trying to update my new Spirit rs from 3.1 to 3.2.2 but cant find version 3.2 anywhere..
PostPosted: Fri 21. May 2021 19:14:07
Just go into Spirit settings software and update and it will automatically find the latest...
PostPosted: Fri 21. May 2021 19:54:16
The spirit setting software tells me that firmaware 3.1 is not compatible with Spirit settings 3.2.2 and i need to update the firmware.
But in update tab it says No awailable firmware..
PostPosted: Fri 21. May 2021 20:22:42
Exactly same as me
PostPosted: Sat 22. May 2021 6:41:34
Now it works :D
just updated firmware sucsessfully.
my guess is that something on spirit´s end was down.
PostPosted: Sat 22. May 2021 8:06:00
Where did you find the firmware link
PostPosted: Sat 22. May 2021 11:44:17
In the good ole days, before 3.2.2 the firmware and 'pc' software were downloaded manually and then nailed together.
Now all you need to do is run the 'pc' software and the program SHOULD find the correct firmware. There have been a few threads on this and there may have been a few teething problems with some people's setups.
Tomas should be along to help out.......
PostPosted: Sat 22. May 2021 12:04:37
I connected to spirit settings and now there was
Firmware updates in the update tab.
PostPosted: Sat 22. May 2021 21:15:13
It's back to working again, all flashed.
Thanks for the input chaps
Users browsing this forum: Bing [Bot] and 64 guests
