It is currently Sat 23. Nov 2024 22:29:03
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Thu 13. May 2021 19:21:22
buttles wrote:
On the bench that's exactly how it should be. If both units are doing it then you have two perfectly good Helis!
Do they fly well??
Not flown the Goblin with this firmware - how should the heli react in the air?
It seems like it doesn not re-centre the swash - whay is that?
I had a DJI Naza H on the Raptor but it was faulty - if I put it into GPS mode it would add a load of collective and then try to go inverted
PostPosted: Thu 13. May 2021 20:02:34
i really wouldn't get too concerned with it. If you have set them up correctly and the swash is level after initialization then just go fly!!
PostPosted: Fri 14. May 2021 9:13:11
I'm not going crazy but Spirit didn't used to behave in this manner?
how will it perform in the air - if I push left alieron and return the stick to centre, will the swash level itself?
PostPosted: Fri 14. May 2021 9:32:35
It will perform ok. It will level the swash quickly. Again, what you are seeing is the bench behavior. If you have followed all the setup steps and verified the correction and direction of the swash movement, everything is fine.
PostPosted: Fri 14. May 2021 17:17:37
I will test fly the Goblin this weekend hopefully, weather permitting
PostPosted: Tue 13. Jul 2021 10:45:03
Finally flew the Goblin - flew very well, no issues with the swash at all.
Thanks for the help and advice
Users browsing this forum: No registered users and 58 guests
