It is currently Sun 24. Nov 2024 1:50:08
 Post subject: Alarm S vibes
PostPosted: Tue 13. Apr 2021 23:43:31
I got the screen with a alarm : Alarm : S vibes < 30% (0)
I have no clou what it means ? :?:
Using a Spirit RS and DS12
Regards , Arno
 Post subject: Re: Alarm S vibes
PostPosted: Wed 14. Apr 2021 7:13:37
This is an external telemetry sensor, from your FBL. The alarm means that the level of vibrations measured by Spirit went over 30%.
I don't know if this is a default alarm created automatically when using the Jeti wizard for Spirit, or you created the alarm in the past.
PostPosted: Wed 14. Apr 2021 8:25:36
It may be a typo in the firmware but that alarm is saying vibes LESS than 30%. Look in the alarms section on the Tx and check what has been set. I would expect to see >30%. I set a number 10% more than my recorded vibes.
PostPosted: Mon 19. Apr 2021 13:54:07
you can delete this alarm. It does not make a sense, because it will trigger whenever vibrations are under 30%. Likely you created it by mistake.
Users browsing this forum: No registered users and 52 guests
