It is currently Sun 24. Nov 2024 4:54:51
[ 4 posts ] |
Dan0111
Posted: Fri 05. Mar 2021 9:09:56 |
i want to use the YGE telemetry with my Spirit RS at E1 but it doesn´t work.
My wiring an programming:
- YGE ESC (tried 65LVT and 95LVT) is set to Jeti protocol - Master plug to THR (black wire to the ground) - blue telemetry plug to E1 (black wire to the ground) - Spirit E1 port is set to Exbus
With a R5L receiver all works fine with the YGE ESC´s, but with the Spirit RS i got no data.
It would be really great if someone else had an idea.
With kindest regards Daniel
Posted: Fri 05. Mar 2021 9:45:05 |
can you share your settings file from Spirit?
Maybe there is some channel assignment for this port in the Spirit unit.
Dan0111
Posted: Fri 05. Mar 2021 16:04:07 |
for sure.
regards Daniel
Posted: Mon 08. Mar 2021 8:35:26 |
Thank you. I have examined settings and I can't find anything wrong there.
For this reason I want to ask you, if you can make sure there is correct settings in the REX-RS for E1 port. Also that ESC settings is really JETI telemetry, not YGE telemetry.
If you will set YGE telemetry in the ESC then there is different wiring with Spirit unit (through SAT port).
These are the only things that could be wrong. Possibly updating ESC to the latest version could help too.
[ 4 posts ] |
Users browsing this forum: No registered users and 36 guests |
