It is currently Sun 24. Nov 2024 5:43:57
 Post subject: Return to home
PostPosted: Mon 22. Feb 2021 21:54:54
Hi there the manual and software seems to contradict each other when return to home on 4 is enabled the manual states it returns to take of position and in the software it states return to power on position. Can anyone verify which is correct?
 Post subject: Re: Return to home
PostPosted: Tue 23. Feb 2021 10:45:20
Surely some one knows the answer?
PostPosted: Tue 23. Feb 2021 14:07:36
there are several modes for Return to Home.
4th function will return model to take off position and is special case of RTH. While the rest will return it to programmed Home point.
PostPosted: Tue 23. Feb 2021 14:09:52
So if I power the heli up on the bench then move it to the take off point it will return to that point it toke if and not over the bench where it was powered up ?
PostPosted: Tue 23. Feb 2021 14:13:23
Yes, that is correct. But 4th RTH mode must be engaged, not other.
You can try it easily in the flight in a high altitude.
PostPosted: Tue 23. Feb 2021 14:14:55
Many thanks for your support. One last thing. I read you helped another customer reset the gyro to fix manufacturing process. Can you tell me how I do this ?
PostPosted: Tue 23. Feb 2021 15:47:03
this process should be done only in case you have some problem and there is no other solution.
Have you encountered something similar?
PostPosted: Tue 23. Feb 2021 16:03:45
No not yet. I haven’t test flown yet.
PostPosted: Wed 24. Feb 2021 19:36:43
the compass calibration was performed in doors when installing the units should i do this outdoor or will this not matter
PostPosted: Thu 25. Feb 2021 0:47:40
Its always best to perform compass calibration out doors in an open area.
Users browsing this forum: No registered users and 11 guests
